September 16, 2016, 11:36 |
Different force for a symmetrical structure
Raja Rout
I need to determine the force along x,y and z axis of a body where the fluid is water. I have considered a sphere and x-direction is the velocity inlet. The force measured along y and z axis are different. As the body is symmetrical then the force along y and z must be same. I don't understand why?
September 21, 2016, 09:26 |
Lucky
Rep Power: 66 |
Are the differences small?
The body may be symmetrical but the solution is not guaranteed to be symmetrical because you are solving a discrete solution on a mesh that is probably not symmetrical. If you want to impose the additional constraint that these forces are the same, then you need to do so and declare this constraint explicitly. If the differences are large, then you've probably made a mistake. |
September 21, 2016, 11:12 |
Raja Rout
Thank you for the reply. Yes the difference is large. I am new to Fluent software so I am sure about the mistakes. But I am not able to recognize it. I am trying to determine the force along the x,y and z axis of an sphere.
ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 11:12 |
How to apply a force on structure | wzhang11 | FLUENT | 0 | September 1, 2014 07:44 |
trying to calculate the dragging force on a structure | pothead | CFX | 0 | June 17, 2014 18:36 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
effect of wind force against structure | zhafir | CFX | 2 | August 23, 2007 18:59 |
