June 4, 2017, 13:31 |
Convergence Problem with PRESTO!
Rep Power: 15 |
Hi guys, I have a Strange Problem I couldn't Resolve.
I have to simulate Flow around a propeller in Fluent in both cavitating and non cavitating states. I did the non cavitating stage good enough with K-Omega turbulence model coupled pressure velocity coupling least square cell based gradient Second order pressure and second order upwind for rest of spatial discretizations. as long as Multiphase simulations Use PRESTO! when I switched to multiphase the solution Diverged after a while. I understood that even without activating multiphase cavitation settings and Just changing pressure spatial discretizations from "second order" to "Presto!" the solution Diverges. Is there any Point I am missing? Where could the problem arise from? Regards. |
divergence, presto! |
Rotate frame reference convergence problem! | wjy-c | CFX | 2 | September 26, 2014 06:03 |
Centrifugal pump OpenFOAM, convergence problem, ANSA model | RDD | OpenFOAM Running, Solving & CFD | 0 | July 5, 2014 09:12 |
Convergence Problem in Axisymmetric Periodic Flow | atheresia | FLUENT | 3 | February 10, 2014 03:00 |
Submerged fin, Convergence problem | supermouniette | FLUENT | 10 | July 6, 2009 10:47 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
