How to calculate torque of the shaft for turbines in CFD fluent simulation ?
Old   September 24, 2016, 23:30
Default How to calculate torque of the shaft for turbines in CFD fluent simulation ?
jeeva B
jeevmech is on a distinguished road
We are working on CFD simulation of hydrokinetic turbine. we are using MRF (multiple frame reference) modeling and calculate torque in CFD fluent software with z- direction has the axis of rotation. whether the torque calculated from CFD fluent is fluid torque or is it the torque of the shaft for the given flow velocity of fluid.
For torque calculation whether 6 degrees of freedom must be considered. Kindly clarify in this regard.
jeevmech is offline   Reply With Quote
Some questions about flow boiling simulation in Fluent beastieboys6 FLUENT 8 November 20, 2017 23:47
Fuel Spray Simulation - How to go about it using fluent? hadiniesta FLUENT 2 May 26, 2017 02:12
Can i calculate output torque ,churning loss ,lubricant temperature,using fluent? mOHAMMAD SADIK FLUENT 0 September 13, 2016 23:26
Fluent & CFD code calculate Static pressure vhcongtltd ANSYS 0 November 2, 2013 08:22
Transport mesh from ICEM CFD, to Fluent, to Sysnoise Wieland FLUENT 2 April 15, 2012 06:28
