boundry condition
Old   September 29, 2016, 02:57
Post boundry condition
ramin
raminostadi is on a distinguished road
Hello expert.
I am working on bifurcating artery. I need to compare my resut with article but I have a problem with boundry condition in that article.
in the article just have been writen 2 sentences about boundry condition:
''The flow is forced by setting pressure difference between inlet and outlets
of the vessel systemThe pressure difference used in the CFD simulation to
force the blood flow was set to 40 Pa which resulted in the flow
rate of 4.5 ml/s''
I am not sure about boundry conditions.
which boundry condition should I put in fluent setup for inlet and outlets?
please help me.
raminostadi is offline   Reply With Quote
Old   September 29, 2016, 05:10
pakk will become famous soon enough
"'The flow is forced by setting pressure difference between inlet and outlets of the vessel system"
So they put a pressure on the inlet and a pressure on the outlet.
"The pressure difference used in the CFD simulation to force the blood flow was set to 40 Pa"
So the inlet pressure was 40 Pa higher than the outlet pressure.
You are probably doing an incompressible calculation. Set the operating pressure at a typical pressure (101325 Pa for atmospheric pressure, I guess blood is in the same range but I am no expert on that), and set the gauge pressure at the inlet at 40 Pa and at the outlet at 0 Pa. Then you did what the article formulated. The flow of 4.5 m/s is a result of the simulation, so you should use that to check your results and not use that as input.
pakk is offline   Reply With Quote
The difference of cyclic boundry condition and mapped boundary condition caitao OpenFOAM Running, Solving & CFD 1 December 4, 2019 07:29
how get boundry condition to air return ducts honest FLUENT 1 July 11, 2011 08:48
Access cell volume from boundry condition JimKnopf OpenFOAM Programming & Development 2 March 10, 2011 04:29
Different Boundry Condition Type at the same face cupidvenus FLUENT 5 September 10, 2009 05:16
Temperature rise at a boundry condition Rodrigo FLUENT 5 August 3, 2001 10:04
