Reversed flow where it shouldn't
Old   October 13, 2016, 08:53
Default Reversed flow where it shouldn't
malleYay is on a distinguished road
Hey guys,
I'm stuck with my simulation and need some help.
I want to simulate flow through a manifold, to get a qualitative result of what the flow might look like.
The manifold is part of a measurement system and i can briefly explain what the flow should look like in there.
We have the main-flow from inlet 1 to outlet 2 due to a delta p which I dont know exactly, I just now that this flow is around 1,5 l/min.
Outlet 5 is the flow to the detector, which is held constant at 120ml/min by a pump and a mfc outside of the fluid domain.
Now the middle one of the three inlets shown in the picture is a special one and actually the one I'm interested in. This inlet is 0,75mm ID pipe and it has a 0,375mm OD/0,03mm ID capillary in it. The outer pipe is an outlet (pump and critical orifice outside flow domain) with around 10ml/min flow and the capillary is an inlet with 0,2ml/min flow. This results in the fact, that the fluid going in through the capillary gets immediately sucked away by the outlet 7, which is intendet.
The fluid through inlet 6 is NO2, whereas the fluid through all the other inlets air is.
After this simulation I want to see how deep does the NO2 get pushed in the manifold (y-direction) before it gets sucked away by outlet 7. I assumed I can use the species transport model with an inert-mixture (because there is no chemical reaction between NO2 and air) to get to this result.
Now my problem is: when I set outlet 7 as pressure-outlet with target mass flow I get reversed flow in this surface. How do I get rid of this?
Some information on my setting:
- k-omega with low-Re correction
- species-transport, inert-mixture (o2, no2, h2, air)
- Minimum Orthogonal Quality =  2.61884e-02
- Maximum Ortho Skew =  8.69166e-01
- Maximum Aspect Ratio =  6.66352e+01
- operating pressure = 25000 Pa
#   type   value
1   pressure-inlet   300 Pa / air
2   pressure-outlet   0 Pa / target mass flow=7,426e-6 kg/s
3   massflow-inlet   0 kg/s (not used in this case) / o2
4   massflow-inlet   6,8926e-11 kg/s / h2
5   pressure-outlet   0 Pa / target mass flow=5,9408e-7 kg/s
6   massflow-inlet   9,9034e-10 kg/s / no2
7   pressure-outlet   0 Pa / target mass flow=4,9507e-8 kg/s
malleYay is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Significant Reversed Flow at Outflow Problems [ANSYS FLUENT] NormalVector ANSYS 1 May 15, 2012 23:50
Reversed Flow for a tenth slice of a rotor neptunemmx FLUENT 10 January 30, 2012 13:51
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
reversed flow Sastry FLUENT 5 March 22, 2007 08:05
