October 12, 2016, 05:29 |
Problem with meshing
Steven Sze
Rep Power: 9 |
I'm new in using this software. I am simulating a vertical wind turbine, and i came across this video, link is below: https://www.youtube.com/watch?v=8NfvIHv78DQ&t=0s I am having trouble doing the exact same meshing. I don't understand how did the person create three different meshes in one planar. Any help will be very much appreciated. |
October 17, 2016, 04:48 |
Rep Power: 10 |
You need to split your current domain in multiple volumes and to mesh these one by one. So open DesignModeler or Gambit or whatever you use for geometry creation, and split the domain as you wish. Then mesh the volumes in Meshing/ICEM/whatever you use. The domain splitting leads to creation of new boundaries (subvolumes boundaries). You can set constraints to every of these boundaries which gives you a better control over the meshing process. Just see the ANSYS tutorials, there are enough examples on this topic.
fluent, mesh, vertical wind turbine |
Problem with querying the meshing database in CFX-Pre | ashtonJ | CFX | 18 | April 18, 2023 23:49 |
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 07:21 |
[ANSYS Meshing] Inflation - Airfoil Meshing - Divergence problem | dalecooper | ANSYS Meshing & Geometry | 0 | July 19, 2013 07:04 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 20, 2006 23:31 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
