CH4-Air combustion temperature too high
Old   June 5, 2015, 07:39
Post CH4-Air combustion temperature too high
US & Canada only
Jill Wu is on a distinguished road
Hi
I got a big problem with non-premix CH4-air combustion. I use laminar flow in my model and the mechanism is SKELWS (35 reactions and 16 species) and the properties: Thermal conductivity use "mass-weighted-mixing-law", Viscosity use "mass-weighted-mixing-law", Mass Diffiusivity use "kinetic-theory", Thermal Diffusion Coefficient use "kinetic-theory".
The nods is about 200 thousand. And the solution method is "SIMPLE", pressure is "PRESTO!" and "Second Order Upwind".
After the solution converge.
The temperature is still very high (3900 K).
If any one know what's going on, please help me.
Thanks.
Jill
Jill Wu is offline   Reply With Quote
Old   October 27, 2016, 10:51
Default High temperature of CH4-Air
luong hung truyen
luonghungtruyen is on a distinguished road
Hi Jill Wu!
I am working with fluent to simulate the laminar diffusion flame for CH4-Air combustion.
Setting density: idle gas, Heat capacity Cp:Mixing law,Thermal conductivity:Idle gas-Mixing law, Viscosity:Idle gas- Mixing law. Mass diffusion: Kinetic-theory
The node number: 11500
Scheme: Simple- 2nd order
The maximum temperature is 4020K
I got the same problem as you. I confuse about this
If you solved the problem please teach me to over come this.
Thank you so much!
luonghungtruyen is offline   Reply With Quote
high temperature
Too high temperature while radiation is on. beerasmus FLUENT 0 January 13, 2014 01:20
Internal field temperature decreases after each iteration (Combustion Modeling) germinal OpenFOAM Running, Solving & CFD 1 November 29, 2010 13:16
how to set radiation model for ch4 air combustion venkat FLUENT 2 May 9, 2007 10:13
High Combustion Temperature in the EBU model Mehdi Siemens 0 April 24, 2006 05:53
Decreasing temperature of combustion Jacek FLUENT 5 February 18, 2002 00:45
