The surface temperature along the length look strength [Microchannel]
Old   November 19, 2016, 10:40
Default Problem with the surface temperature [Microchannel]
Siripak Sangsinsorn
zrp3s is on a distinguished road
I'm new of fluent but I'm trying to simulate a microchannel.(follow this study >>https://drive.google.com/drive/folde...kFTQ1c0a0p5NFE)
My modeling has two zones a solid zone,Copper and the fluid zone,water.
These are my boundary conditions.
1.The bottom wall of Copper has constant heat flux = 1,000,000 W/m^2
2.All outside walls of Copper (Except the bottom) are adiabatic walls (Heat flux = 0)
3.The interfaces between the solid and fluid are coupled
4.The inlet is used velocity inlet .
5.The outlet is used pressure outlet.(I didn't type any data in this condition.)
So, I found that the summation of the heat of all interfaces equal to the heat from the bottom.It makes sense !
(the heat of an interface = average heat flux that was calculated from the program multiple the area of that interface)
But, The temperature on the surfaces looks strange. This picture shows the bottom interface temperature and the bulk temperature (i made the line at middle of fluid)
What's wrong with my model ?
Thanks in advance for any help that you are able to provide
zrp3s is offline   Reply With Quote
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 09:21
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
how to get surface temperature of pipe at cross section using iso-surface ashgun FLUENT 8 June 2, 2013 02:03
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
Surface temperature on tube surface Anuj Phoenics 1 November 28, 2006 19:24
