December 4, 2016, 06:20 |
Negative Room Pressure
Angel
Hi, I'm a student and in my Master’s degree final project i have to simulate a Negative Room Pressure.
In this case, I have 2 rooms: - An anteroom, where I have to get -2.5 Pa - The patient room --> -5 Pa Both rooms are conected by a gap around the door. Both rooms have air difussers (with a ventilation system that removes more exhaust air from the room than air is allowed into the room) and gaps around other doors and windows (boundary condition = pressure inlet 0). The main problem is that i never get a convergence. I tried to separated the room in three bodies: - Anteroom - Patient Room - Gap door. I made a structured mesh in this body, because i thought the problems were here, but them remain. So I have no idea what is wrong. I simulate with standard k-e, althought I have tried other methods. I wonder if the problem is that is no possible to maintain in contact two different pressure, or something like that. On this aspect, I would like to ask for your help. |
December 4, 2016, 08:16 |
#2 | |
Quang Le Dang
Rep Power: 14 |
December 4, 2016, 10:14 |
Angel
When i said negative pressure, i referred to gauge pressure, sorry.
December 5, 2016, 08:26 |
Quang Le Dang
Rep Power: 14 |
So, do you use gauge pressure for simulation? Because in simulation, I always use absolute pressure. Also, check operating condition pressure. And let me know your simulation in details (Boundary condition, mesh, etc).
convergence, divergence, negative pressure, room |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 13:04 |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 16:29 |
Negative pressure | jcamilleri | STAR-CCM+ | 1 | April 10, 2014 05:27 |
negative pressure | mAx | FLUENT | 0 | January 25, 2006 14:31 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
