January 16, 2017, 07:56 |
Particle tarcking
Rep Power: 9 |
Hi guys
I am trying to simulate a particle tracking project in a 90 bend with DPM model in fluent 14. the viscous model is RSM-EWT. In DMP model i set the " Max number of steps" to 5000 and " step length factor" to 5. there is no interaction between particle-particle and particle-continuous phase. I have used Rungt-kutta method for "tracking scheme". I also created an injection with this following option: injection type: surface-inlet particle type: inert inject using face normal direction: d=4.7e-06 m v=18 m/s flow rate=1.2e-09 kg/s this is equal to 25000 particle. in every run that i have performed just 336 particle were tracked. I have changed the flow rate,velocity,diameter,number of steps but in all cases results were same. Can any one help me to solve this problem? |
UDF for particle interception with pt_termination fortran routine | abcdefgh | CFX | 6 | October 6, 2019 13:30 |
Particle tracking error | alchem | OpenFOAM Bugs | 5 | May 6, 2017 16:30 |
particles leave domain | Steffen595 | CFX | 9 | March 7, 2016 16:19 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
