Natural Convection in an enclosure
Old   January 24, 2017, 09:18
Default Natural Convection in an enclosure
Asiyanbi Naim Abiodun
Ifenaim is on a distinguished road
Am running an analysis on natural convection in an enclosure with FLUENT 14 using standard boussinesq air properties ,what is the yardstick for choosing the operating temperature?
How do i define the Rayleigh number since it is not available as input parameter in fluent?
Do i have to read the fluid properties at the chosen operating temperature?
Ifenaim is offline   Reply With Quote
Old   January 24, 2017, 23:39
Vignesh Lakshmanan
ViLaks is on a distinguished road
I think you have to specify the fluid props in the materials panel to input the Rayleigh number. Regarding Operating temperature, I cant be of much help because I too have the same question
Regards
Vicky
ViLaks is offline   Reply With Quote
Old   January 24, 2017, 23:51
Default NAtural Convection in a closed ENclosure
Vignesh Lakshmanan
Hi All,
I am trying to simulate using Fluent natural convection inside a deep freezer geometry, whose walls are maintained at 253 K and the air inside is at 316 K. My aim is to simulate the time required for cooling of air from 316 to 255 K . My questions are:
1) What should be the temperature at which I can define material properties of air ? ( Is it the wall temperature or air temperature?)
2) What should be the operating temperature in my case?
3) Also should the operating temperature and the input density be given as reference values also??
I am planning to use the Boussinessq approximation and run a transcient simulation but the material properties are confusing me
Thanks and Regards
Vicky
Old   April 11, 2017, 10:22
alireza keyhani
ali_reza is on a distinguished road
hi
could you explain more about your problem specially your boundary conditions.
how are the walls of your enclosure ?
regards
ali_reza is offline   Reply With Quote
enclosure, natural convection, operating temperature, rayleigh number
natural convection enclosure problem satendra chauhan Main CFD Forum 0 August 2, 2015 13:00
Natural convection in oil filled enclosure abu250feldman FloEFD, FloWorks & FloTHERM 5 December 4, 2013 09:37
natural convection problem with radiation jorien CFX 0 October 14, 2011 09:26
Coupling a wall conduction with natural convection in a rectangular enclosure mebrouki FLUENT 0 March 7, 2010 03:32
natural convection in a sealed enclosure James Main CFD Forum 4 April 2, 2001 15:48
