to determine Integral length scale in Fluent
Like Tree1Likes
  • 1 Post By CeesH
Old   February 6, 2017, 01:28
Default to determine Integral length scale in Fluent
raunak jung pandey
raunakjung is on a distinguished road
Hello everyone
I am trying to calculate integral length scale in Fluent for a fluidic oscillator. My objective is to carry out LES simulation.
I am using the expression :
integral length scale l0 = k^1.5 /e where k - turbulent kinetic energy and e is eddy dissipation.
During post processing maximum and minimum values of turbulent kinetic energy and eddy dissipation rate is given. Can these values used to determine integral length scale.
If not what is the process to determine integral length scale?
Thank You
raunakjung is offline   Reply With Quote
Old   February 6, 2017, 02:56
Cees Haringa
CeesH is on a distinguished road
You can make a custom field fuction (under define) with the required equation. This will calculate the length scale in every grid cell. You can then plot it as a contour plot, export it, like you could do with any field. You can also define an equation in CFD post alternatively.
CeesH is offline   Reply With Quote
Old   February 6, 2017, 03:46
raunak jung pandey
Thank You for your answer. I made a custom field function calculator to determine integral length scale. I have the maximum and minimum values. My goal is to carry out LES simulation. Which value should I use to determine the size of my grid for LES simulation. The maximum or minimum.
Thank YOU
Old   February 7, 2017, 09:03
Cees Haringa
For LES, calculate the Kolmogorov scale, and try to locally refine your mesh to approx. 5-10x the Kolmgorov scale in the bulk. The finer, the more scales you resolve of course.
Darko likes this.
eddy dissipation rate, integral length scale, turbulent kinetic energy
Evaluation of length scale ratio for LES, DES, SAS etc. siw CFX 12 May 19, 2016 02:25
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 07:22
Modelled Length Scale in SAS-SST Simulation jego Main CFD Forum 0 January 16, 2016 06:45
DPM: Particle Tracking Madhukar FLUENT 1 July 24, 2007 03:51
Von Karman Integral Length Scale Txingurri Main CFD Forum 0 May 2, 2002 12:05
