February 15, 2017, 15:22 |
mass balance in DPM, evaporated droplets and the DPM flux?
Zari Musavi
Rep Power: 12 |
I have injected a DPM source with mass flow rate of 0.000139211 kg/s , all particles are also evaporated BUT, when looking at the mass fluxes https://drive.google.com/file/d/0B7p...ew?usp=sharing and dpm-summary https://drive.google.com/file/d/0B7p...ew?usp=sharing, the mass of the evaporated particles are not the same! It is just 4.107e-05 kg/s as dpm-summary says. which one is the correct report? injection: pressure swirl atomizer, steady particle tracking, droplet (+non-premixed combustion) Model: 2D-Axisymmetric Swirl (so the entered droplet flow rate is the global mass rate) I appreciate if you can give me some suggestions of the mistakes. Best, Zari Last edited by Zari; February 16, 2017 at 04:24. |
March 27, 2017, 02:11 |
Behrooz Jamshidi
Rep Power: 13 |
Hi
I hope I wasn't too late. The dpm-summary is correct and must be equal to DPM mass flow if all particles are evaporated. How do u recognize all particles are evaporated? maybe some of them are trapped by other boundaries. |
March 30, 2017, 04:58 |
#3 | |
Zari Musavi
Rep Power: 12 |
Thank you for the reply, Regarding the particles state (scaped, evaporated, incomplete, ...) I see it during the iterations on the console. I also check it by dpm summary, and by Injection list. One thing I learnt is that the better way for the evaporated mass of particles is to use Report/volume report/Sum 2pi, on the dpm mass source in the fluid zone. Because the model is based on 2d-axisymmetric and total mass of the dpm could be integrated in this way. |
DPM Mass Source Quantlity for Coal Combustion | marauder | FLUENT | 2 | May 16, 2017 18:56 |
Mass Flow rate in DPM model | tohidtkz | FLUENT | 0 | November 7, 2015 04:13 |
DPM injection mass flow rate | kingpots | ANSYS | 0 | November 22, 2012 11:12 |
Mass balance problem! | JADG | FLUENT | 4 | December 27, 2003 10:40 |
Mass balance | Sumon | CFX | 2 | March 20, 2002 18:27 |
