Bulk Temperature
Old   February 19, 2017, 13:49
Default Bulk Temperature
Zohud Mohammed
Zohud is on a distinguished road
Dear all; i am studying the heat transfer of nanorefrigerant in horizontal tube under heat flux constant; but i need a method for calculate the bulk temperature of fluid for every points on axes x. I am trying write udf but there is an error
UDF for calculate the bulk temperature
#include "udf.h"
DEFINE_Tb(Tbulk,thread,temp)
real Tb;
real x[ND_ND]; /* this will hold the position vector */
real y[ND_ND];
real u=f_U(f,t)
real temp = F_T(face, thread); /* get face temperature */
face_t f;
begin_f_loop(face,thread) /* loops over all faces in the thread passed
in the DEFINE macro argument */
Tb = SUM u*temp*y / SUM u*y;
end_f_loop(face,thread)
Please help me
Zohud is offline   Reply With Quote
Old   February 22, 2017, 20:18
Zohud Mohammed
Dear all; No one can help me? Please I need your helps
Old   February 23, 2017, 07:30
Kevin
KevinZ09 is on a distinguished road
Well, perhaps specify more clearly what the error is so people on here can help you better. Looking at your UDF, I can see multiple errors:
- What's DEFINE_Tb? Never heard of that macro. You can't just create your own macro's; you need to stick to those provided by Fluent.
- You're referencing variables like face, f, t that are either not defined at all, or defined after using them.
- What is this supposed to do: Tb = SUM u*temp*y / SUM u*y;
I'd strongly suggest first looking in Fluent's UDF manual to get a better understanding of what they do and how to use them. And also look up for information on C programming. That alone should help you solve many of the errors you get.
KevinZ09 is offline   Reply With Quote
Old   February 23, 2017, 13:14
Zohud Mohammed
Thank you Kevin for the comment
determination of the bulk mean temperature for Nu calculation aalzoubi06 OpenFOAM Post-Processing 1 December 2, 2015 17:18
bulk temperature Ice man FLUENT 0 May 29, 2014 03:31
Bulk mean fluid temperature in internal flow mssound FLUENT 0 May 13, 2010 15:56
Bulk temperature emad FLUENT 0 February 1, 2008 07:45
Bulk temperature rjhoti FLUENT 0 April 16, 2003 09:22
