Fluent Airfoil Analysis: Fixed CL mode
Old   February 28, 2017, 05:25
Default Fluent Airfoil Analysis: Fixed CL mode
Bulk is on a distinguished road
I've performed some analyses on supercritical airfoils with the code SU2; I used the 'FIXED_CL_MODE' of Su2, to evaluate the behaviour of the airfoils at different Mach conditions, fixing the target CL (useful to evaluate de Drag Rise condition and the influence of the lift coefficient on transonic performances).
I want to realize the same analysis in Fluent, but I don't know if is it possible to perform a FIXED CL calculation in Fluent. Is there a way (not only a direct command but also a script) to fix the target CL before performing a 2D calculation in Fluent?
Thank You!
Bulk is offline   Reply With Quote
airfoil, fixed cl, fluent, transonic
Problem with airfoil shape optimization robyTKD SU2 Shape Design 7 March 7, 2022 16:18
fluent 12.1, batch mode in linux sakalido FLUENT 13 September 27, 2017 08:55
Fixed CL mode in SU2 V4.2 ygd SU2 0 November 15, 2016 09:59
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 09:26
Fluent Batch Mode Reg_ Urgent Help Required alligngr8 FLUENT 4 January 12, 2012 08:21
