Transporting Plasma from Inlet to Outlet
Old   March 2, 2017, 12:11
Smile Transporting Plasma from Inlet to Outlet
FluidFlowScience
FluidFlowScience is on a distinguished road
Argon Plasma Mass Fraction Picture:
Mesh Picture:
First, thank you so much for your interest in my question!
My question is: how to simulate a plasma jet stream that will travel .1437 meters through a fluid domain of air without dissipating. The closest I have gotten is about 1/3 of the way before the plasma dissipates.
Information:
The image shows the result of plasma entering a fluid domain filled with air at 1000 m/s at 300K. I ran the simulation for a total of 600 timesteps at 2.5e-7 second time step size. The rectangular mesh has a width of .0005 meters which gives me a Courant number of .5. I am using a transient model and 2D axisymmetric.
Other conditions:
  • Models: Viscous k-epsilon (2eq) model, Realizable k-e, Scalable Wall Fn
  • Models: Energy and Species Transport on
  • Operating pressure at 0 pa and outlets' gauge pressures at 1 pa
  • Plasma-Air Mixture: Density = volume-weighted-mixing-law. Specific heat = mixing-law. I chose this because plasma and air have different specific heats. Is this the right choice?
  • Solution Methods: This time I used first order discretization. I will try second order once I know the solution is close to being correct.
  • Which Turbulence specification method should I choose for the inlets and outlets?
I will soon be running the simulation again with 5000K at the inlet to better simulate plasma.
Again, thank you very much for any assistance you can give! If you need more information or have any questions about my set up, please ask!
FluidFlowScience is offline   Reply With Quote
axisymmetric 2d fluent, plasma flow, species transport
Calculate Mass Flowrate and Mass Flow Averaged Total Pressure at inlet and outlet coolcrasher OpenFOAM Post-Processing 7 November 4, 2021 04:57
massflow of inlet and outlet are not equal knoedl1 OpenFOAM Running, Solving & CFD 11 July 3, 2018 14:00
UDF profile: Fluent method for coupling inlet and outlet I-mech Fluent UDF and Scheme Programming 0 May 10, 2014 10:36
Inlet but not outlet mireis FLUENT 1 June 10, 2010 10:56
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
