Negative Pressure at flow front with VOF model |
March 7, 2017, 04:59 |
Florian Piott
I'm trying to simulate the flow of plastic mold with high viscosity through carbon fibres in a 2D. Therefore I'm using the VOF-Multiphase model.This is similar to the flow around cylinders. The problem is, that after very few time steps there is a very high negative pressure near the flow front. I've tried many different solution methods and boundary conditions but nothing seems to make the solution better. Has anyone ever had the same Problem or any idea how to solve it? Thank you in advance for your help! |
negative pressure, plastic mold, vof |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 10:40 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
