Fluent memory leak problem on windows 10? |
March 25, 2017, 14:15 |
Daniel
Rep Power: 21 |
I'm running fluent simulation on windows 10 but it seems that I'm facing memory leak problem....
I'm running 4m grid with the following setup: - Transient, VOF, SIMPLE, second order discretization - Turbulent: Realizable K-Epsilon with menter-lechner - Dynamic mesh, spring method Here is the spec of the system I'm using: - Core i7 6700K - 32GB DDR4 RAM At the beginning of the simulation it only uses 50% of the memory. However after 1 day, it almost uses all of the memory and finally get terminated with low memory error What's the problem? how much RAM a 4m grid domain needs for the aforementioned case setup? Best wishes, Regards |
March 26, 2017, 00:37 |
Daniel
Rep Power: 21 |
well after watching the simulation, it seems the memory consumption grows by every auto case and data writing
why does it keep case and data in memory after writing it to HDD? |
March 26, 2017, 01:30 |
Lucky
Rep Power: 66 |
Are you sure it's not because of your dynamic meshing?
March 27, 2017, 01:48 |
SinaJ
Rep Power: 16 |
I recently did a transient multiphase simulation with ~6M cells on a linux cluster of ~150 cores (means too much communications involved) with less than 20GB of ram! My point is that there is something wrong!
It must be with dynamic meshing. Create a monitor and write the mesh-size as a text file so you can have a record of mesh size after it gets terminated. So you can check when/why the mesh gets too fine! |
March 27, 2017, 17:44 |
#5 | |
Daniel
Rep Power: 21 |
March 28, 2017, 10:07 |
#6 | |
Daniel
Rep Power: 21 |
March 28, 2017, 13:29 |
#7 | |
SinaJ
Rep Power: 16 |
Well, this is weird then. 4.1M is nothing for 32GB of ram. I would also try to check if the license manager is working well. How long did it take to get to 1500 time steps? Is this 4.1M the latest mesh size? My point is that a crazy mesh-size increase can happen in just few time steps. You need to know the cell number for every time step. |
March 28, 2017, 15:49 |
Lucky
Rep Power: 66 |
You could also just turn off dynamic meshing altogether. Do you actually need a dynamic mesh in your problem?
March 28, 2017, 16:51 |
#9 | |
Daniel
Rep Power: 21 |
It starts with 47% memory usage and then gradually increases after every case and data writing. For example from 47% to 53%, 60%, 68%, ..., 100%!!!Everything is normal when I check the written case and data files, even their size are consistent with the initial case and data! The calculation speed is also consistent... I have checked all of the written case files: in a few steps the cell count drops to 3.8m, however the memory usage still increased well I'm simulating a ship hull and the ship motion through waves is important for me! |
March 30, 2017, 04:18 |
#10 |
Daniel
Rep Power: 21 |
Well it seems that ANSYS 17.1 has memory management problem on windows 10 and keeps case and data in memory even after writing it to HDD.
Asked my supervisor to upgrade ANSYS to version 17.2 and the problem is now gone...memory usage remains at 47-50% all the time |
Fluent - license problem. | Marcin | FLUENT | 3 | April 13, 2018 16:33 |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
Fluent Parallelization Problem After AC Power Dropped | pawl | Hardware | 5 | November 13, 2016 06:08 |
Memory problem in Fluent | sai | FLUENT | 0 | January 30, 2007 05:32 |
"Memory too low" problem with Fluent HELP NEEDED | Amr | FLUENT | 6 | May 8, 2006 12:06 |
