Maximal pressure problem, multiphase simulation |
March 28, 2017, 04:19 |
Multiphase simulation ,flow focusing
caroline
Rep Power: 9 |
Hello everyone,
I'm new on Fluent, I must do a practical exercise. I need to simulate flow focusing from this microchip : exercice 1.png I have flow rate of both inlets and maximal pressure of the system I have to find : - InSheath q = 9 µL/s - InSample q = 1 µL/s - Pmax = 800 mbar For this work I have set the following conditions : -> Models : Viscous (Laminar) + Multiphase VOF (basics parameters, 2 Eulerian phases), Primary phase : sample, Secondary phase : sheath, liquid water both, no interaction between phases. -> Boundary conditions : - InSample, velocity inlet : 1,0e-4 m/s, gauge pressure 0, sheath volume fraction 0. - InSheath, velocity inlet : 1,0e-3, gauge pressure 0, sheath volume fraction 1. Basics conditons for the others. -> Methods : exercice 1.png -> Initialization : Standard, compute from : all zones -> Run calculation : - Time stepsize : 1 s - Number of time steps : 0 - Iterations : 100 I can not find the maximal pressure preticted. Please, could you tell me if something wrong on my setup, and why I can not find the good result!! HELP PLEASE Last edited by Cmaroline; March 28, 2017 at 09:53. |
March 28, 2017, 13:06 |
SinaJ
Rep Power: 16 |
Do you get any errors?! Can you for instance get the velocity magnitude contour working?
BTW, number of time steps = 0? It means that technically it doesn't run the simulation, does it? |
March 29, 2017, 03:31 |
caroline
Rep Power: 9 |
I don't have any error. Velocity magnitude is equal to 0, all the piece is blue.
I try with time step size = 1.0e-5s and number of time steps = 1 it is always the same result. I don't understand why. I've been on this exercise for almost three weeks, I'm desperate. |
March 29, 2017, 08:43 |
Rep Power: 9 |
The solution converges though ?
I am very unexperimented in transient simulation, but i do agree with sina_mech's point... Why do you have so few time steps ? Shouldn't there be much more ? btw, we don't know much of the exercise in itself, so it'll be hard to get relevant help on it... |
March 29, 2017, 10:47 |
#5 | |
SinaJ
Rep Power: 16 |
March 29, 2017, 11:00 |
caroline
Rep Power: 9 |
I'm an wondering! Would it be possible to use the discrete phases model?
sina_mech : How to make a file "Case+data"? |
March 29, 2017, 11:15 |
#7 | |
SinaJ
Rep Power: 16 |
For your second question: You have 2 different inlets, with 2 different materials. You need a multiphase model. You can't model the secondary phase inlet, just by DPM. |
March 30, 2017, 03:55 |
caroline
Rep Power: 9 |
I watched some tutorials on youtube, and I made tutorials and I succeeded. But when I come back on this exercise... I can't find similar tutorial...
I stay on VOF model, and I will see parameters of "Run calculation" like time of step and the others. It is not really easy for beginner... Someone told me about USD for materialize one of both phases. Can this help? |
Pressure drop in pipe flow with Large Eddy Simulation | xerox | FLUENT | 1 | October 16, 2019 08:55 |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
Pressure Problem - Mesh Motion - Multiphase | ErdemKaya | Fluent Multiphase | 0 | December 28, 2015 04:44 |
what boundary condition is proper for simulation of shock-tube low pressure part? | immortality | OpenFOAM Running, Solving & CFD | 0 | May 2, 2013 13:22 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
