March 31, 2017, 01:12 |
Scale the geometry in solution workbench
Gurjeet Singh
Rep Power: 9 |
Hello all,
I have created my geometry in micrometers in fluent design modeler and meshing is done by choosing number of divisions in x,y and z direction in fluent itself. I have doubt that before run the simulation do I need to scale the geometry in solution workbench ? I am facing the problem that even after dividing the geometry in huge number of elements my solution of continuity equation is not converging beyond 2e-3. My problem is associated with the analysis of fluid flow and heat transfer in multiple parallel channels. |
Workbench 18.0: Geometry Error Related to Pre-Meshed Crack | Light_of_Aether | ANSYS | 3 | November 12, 2017 20:58 |
FLUENT installation on UBUNTU 12.04 (LTS) | teymourj | FLUENT | 2 | March 1, 2017 22:24 |
[snappyHexMesh] Solution Snappy Hex 2D Msh with Surface Layers and cyclic bc for symmetric geometry | flexi182 | OpenFOAM Meshing & Mesh Conversion | 0 | May 24, 2013 08:38 |
number of iterations to converge solution in Fluent as Ansys Workbench output param | nnvoro | FLUENT | 4 | May 2, 2013 01:18 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
