April 10, 2017, 08:16 |
Closing Inlet after 70 timesteps
Usman Ahmed
Rep Power: 9 |
Hi I want to close pressure inlet after 70 timesteps and open pressure outlet from 71 how do I acheive that !!!
Sent from my SM-A310F using CFD Online Forum mobile app |
April 10, 2017, 12:22 |
Gonzalo
Rep Power: 16 |
You can do that by stopping the simulation after 70 timesteps and then changing the BC from Pressure Inlet to wall, and change all the BC you want to. Fluent will preserve the result from the previous timesteps, and you can use them. Regards
April 10, 2017, 12:28 |
Usman Ahmed
Rep Power: 9 |
Am simulating compressed air inside a cylinder with piston the air starts to hit the wall of cylinder directly after 30 40 time steps and does not flow in the whole cylinder or act on it
April 10, 2017, 14:45 |
Gonzalo
Rep Power: 16 |
Oozmi, I can't understand your problem. Can you be more specific?
April 10, 2017, 14:55 |
Usman Ahmed
Rep Power: 9 |
This is the problem when piston starts to move towards BDC the pressure from iblet only hits the cylinder wall and does not go beyond that Sent from my SM-A310F using CFD Online Forum mobile app |
setting the correct format of nonuniform List<vector> for inlet in 0 Folder | cfdonline2mohsen | OpenFOAM Running, Solving & CFD | 8 | July 18, 2019 08:03 |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 04:58 |
"Closing" a pressure inlet via UDF? | dave88 | Fluent UDF and Scheme Programming | 0 | August 27, 2013 18:14 |
Inlet Velocity in CFX | aeroman | CFX | 12 | August 6, 2009 18:42 |
Diffusion component at inlet | Balaji | FLUENT | 2 | August 8, 2005 07:37 |
