Fluid Structure Interaction (FSI) - 2/Way
Old   May 2, 2017, 14:44
Default Fluid Structure Interaction (FSI) - 2/Way
Fabricio
fabriciotb is on a distinguished road
Send a message via MSN to fabriciotb Send a message via Skype™ to fabriciotb
Hello.
My work consists of two concentric cylinders in order to the internal cylinder is an solid cylinder with fixed angular velocity and the external cylinder is a fixed domain being the stationary fluid domain.
The normal procedure are transfer the forces from fluid (Fluent) to solid body and receive from solid body (Mechanical) the displacements. Additional that, I need to transfer the angular velocity from rigid body (Mechanical) due a torque to fluid domain (Fluent) through the interface, but I can't do that.
Please, someone could help me to resolve it?
Is it possible to create a external routine to do that? The APDL could be an option?
Thanks.
fabriciotb is offline   Reply With Quote
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Simple FSI (fluid structure interaction) Problem kilroy Main CFD Forum 0 January 7, 2015 14:42
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
Fluid Structure interaction (FSI) osirous FLUENT 5 July 5, 2011 15:38
Fluid Structure Interaction and OpenFOAM capabilities paka OpenFOAM Running, Solving & CFD 1 June 6, 2007 13:56
