DPM monitor problem
Like Tree3Likes
  • 1 Post By sina_mech
Old   May 14, 2017, 13:18
Default DPM monitor problem
Danial
Danial1992 is on a distinguished road
dear friends,
I am going to model sedimentation in a tank which water and solid like sand flow through it, I've done the water flow calculation, and also I know how to model solids as DPM. my question is that how can I monitor that how much of solid goes out of the tank?how can I monitor the out let?
thanks
Danial1992 is offline   Reply With Quote
Old   May 14, 2017, 13:37
SinaJ
sina_mech is on a distinguished road
Originally Posted by Danial1992 View Post
dear friends,
thanks
Hi Danial,
You can use "Sample" feature via : Report -> Discrete Phase -> Sample ...
Choose the surfaces you're trying to monitor, "Start" sampling, run the simulation, and "Stop" sampling at the end.
Danial1992 likes this.
sina_mech is offline   Reply With Quote
Old   May 14, 2017, 15:43
Danial
Originally Posted by sina_mech View Post
Hi Danial,
thanks, dear Sina, I want to see how much solids will remain in outlet flow. Is it possible? how can I do it?
Old   May 14, 2017, 15:47
SinaJ
Choose "Outlet" as sampling surface, and after stopping the sampling, you will have .dpm file for outlet. That's an ASCII file, so you can open it using a text editor (and even Excel), and simply sum up the mass of the collected parcels at that surface.
Old   May 15, 2017, 08:24
Danial
thanks a lot,
I am facing a problem ,I follow ur instructor and as I start this Error comes ('Warning: unable to append to file out.dpm, opening new file.'), whats the problem? what should I do?
Old   May 15, 2017, 11:19
SinaJ
You have probably enabled the "Append file" option. When you have it ON, it will search for any existing sampling file to append the new samples to those files. When you don't have any sample files, that warning pops up, and it is not a big deal. If there is no existing file, it will create one.
Old   December 27, 2022, 06:43
nicola
yanqoue is on a distinguished road
I'm also having the same issue, how did you solve it?
I get this warning:
"Warning: unable to append to file out.dpm, opening new file."
Then it proceeds to create several files for the same plane. I either have to find a way to merge separate files into one single file or find a workaround for this.
yanqoue is offline   Reply With Quote
Dem v.s dpm? Amir1 Main CFD Forum 1 November 3, 2019 09:52
DPM mass flow kingpots FLUENT 0 November 29, 2012 22:20
Dpm injection mass flow rate diamondx FLUENT 0 November 22, 2012 13:04
DPM injection mass flow rate kingpots ANSYS 0 November 22, 2012 11:12
slow after mesh for enhanced wall treat DPM joshkemp FLUENT 0 May 1, 2007 17:20
