June 8, 2017, 04:31 |
Meshing
yoman
Can anybody tell me pls what change there will be if meshing hexahedral is not in my setup ..than how will differ the result tetrahedral ....what is basic diiference in calculation n all in case of numerical investigation of natural convection heat transfer over annular finn case is taken for numerical investigation...thank you all suggestions wellcome
June 8, 2017, 09:20 |
Rep Power: 13 |
I'm not sure how well tetra results compare in general to hexaeder results. I can imagine results can be identical. What i know is that you will need a lot more cells and therefore more computational time to get to (same) results as the hexaeder solution.
Also for multiphase analysis it is always better to have hexaeder mesh, because the interphase is captured more realistic. |
June 11, 2017, 15:09 |
Lucky
Rep Power: 66 |
On a tetrahedral grid, the calculation of gradients is tough and this gradient is needed for everything in FVM.
One would hope that tets vs hex's are the same, but that simply isn't true from a practical standpoint. |
[ANSYS Meshing] only automatic meshing works, | kazra | ANSYS Meshing & Geometry | 2 | February 23, 2017 11:38 |
[Gmsh] 3D coil mesh: can't create the volume? | RomainBou | OpenFOAM Meshing & Mesh Conversion | 3 | July 18, 2016 05:09 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
