LES of turbulent channel flow (overprediction) |
June 19, 2017, 11:33 |
Nathan Ricks
Rep Power: 10 |
I'm trying to simulate the classical case of turbulent channel flow at Re = 180 with Ansys Fluent 15.0, using LES (with dynamic smag SGS model, and an in-house SGS model). The simulation is running, and seems to give trends as expected, however we are seeing an overprediction in the mean streamwise (x) velocity - ~21m/s compared to ~18m/s in the literature. Does anyone have any experience with this particular case in Fluent, and can give me some hints/point me towards a tutorial, etc? Some of the major setup points include: - Periodicity in the x (streamwise) and z (cross-stream), with walls in the +/- y direction The periodicity was defined in fluent, using modify zone. The pressure gradient is defined as -1 (from dP/dx = density*(u_fric)^2), with flow direction = [1,0,0] - this is one of our concerns, is this correct for Fluent? - CFL and wall y+ < 0.5 - Grid and domain defined consistent with literature - Flow initialised using k-epsilon RANS, and then init-instantaneous-vel If any more details would be helpful I'd be happy to give. Any help would be much appreciated! Thank you in advance, Nathan. |
March 3, 2024, 21:47 |
turbulent plane channel flow
Song Shanshan
Hi, sorry to bother you, but has your problem been solved? I've just recently started dealing with this issue and am not sure how to work about it?Could you give some help?
channel flow, fluent, les, periodic bc, pressure gradient |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Turbulent transition in channel flow | yansheng | STAR-CCM+ | 11 | June 16, 2016 09:05 |
Calculate statistics of Turbulent channel flow with LES | sjwon1991 | Main CFD Forum | 2 | May 10, 2016 23:31 |
references for how to maintain a constant flow rate in turbulent channel flow | amirrstg | Main CFD Forum | 0 | October 25, 2011 03:17 |
Initial conditionfor turbulent channel flow in LES | pankaj saha | Main CFD Forum | 0 | November 30, 2007 12:04 |
