Translational+rotational periodic flow
Old   June 1, 2017, 21:04
Default Translational+rotational periodic flow
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Hello CFD experts,
I want to model a flow with periodic boundaries. The flow is rotational as well as translational periodic in nature. (Please see attached figure). Therefore I have modelled a 3d helical periodic segment. In Fluent, under Periodic conditions, I gave MFR and Bulk temperature as 298.15. While the outer wall heat flux is 298.15 K. The contours formed for temperature are pretty strange. Since the geometry contains helical shape,the translation distance in the figure is upto 1 pitch length (12.7 mm), which is for helix angle 60 degree. Please help me, why the temperature is not resolving right? Will, the boundary conditions "velocity inlet" and "pressure outlet" (instead of translational periodic) help?
Shamoon Jamshed is offline   Reply With Quote
Old   June 5, 2017, 08:18
Shamoon Jamshed
Hello friends,
Please help me out in this problem, I would be grateful to you!
Old   June 14, 2017, 19:15
Shamoon Jamshed
Dear Friends,
Any idea on how to fix this problem?
Old   June 18, 2017, 10:58
Shamoon Jamshed
Dear CFD fellows,
Please help me in this problem, I would be thankful to you, I am also attaching an image showing the above problem
Old   June 21, 2017, 22:01
李弘扬
lihongyang0 is on a distinguished road
I want to check your case file. You could send me the files. lihongyang0@126.com But I am not sure I could solve your problem.
lihongyang0 is offline   Reply With Quote
Old   June 24, 2017, 09:24
李弘扬
I have recieved your case. You mean the temperature is low at the rotational periodic face?
Old   June 24, 2017, 10:09
Shamoon Jamshed
NO, I mean when you run the simulations, after convergence, the results of temperature are like the one mentioned in figure which should not be the case, since we are applying flux at top, the temperature field must be uniform at a given cross section.
Periodic Pipe Flow LES dvolkind CFX 8 March 21, 2020 05:30
Translational+rptational periodic flow Shamoon Jamshed FLUENT 0 June 1, 2017 21:03
No flow through periodic (cyclic) boundaries in impeller with foam-extend-3.1 anttiad9000 OpenFOAM Running, Solving & CFD 3 March 2, 2016 19:37
periodic flow-solve flow equation Lilly FLUENT 5 March 4, 2013 07:10
Periodic boundary condition - pipe flow -setting up heat transfer Explorer FLUENT 0 December 4, 2012 03:36
