July 5, 2017, 05:03 |
Uninitialized flow field
Rep Power: 9 |
I am trying to run an analysis of turbulent water flow in a pipe driving a submerged water turbine. I keep getting the message below: WARNING: Unassigned interface zone detected for interface 9 Unassigned interface zones found. Flow is not initialized. iter continuity x-velocity y-velocity z-velocity k epsilon time/iter Error at host: Iterate: uninitialized flow field Error at Node 0: Iterate: uninitialized flow field Error at Node 1: Iterate: uninitialized flow field Error at Node 2: Iterate: uninitialized flow field Error at Node 3: Iterate: uninitialized flow field Error: Iterate: uninitialized flow field Error Object: #f Calculation complete. Does anyone know how to resolve this problem? |
pipe, turbine, turbulence, water |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[ICEM] Circular 2D Flow Field Setup - | Bourke | ANSYS Meshing & Geometry | 2 | December 10, 2015 21:51 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
