July 10, 2017, 06:30 |
Fluent error in saving
Njit
Rep Power: 9 |
Hi
I am facing a problem in saving after running calculation in FLUENT 16. Sometimes, this problem comes up even when i start to calculation. the error message shows like: C:\Users\Admin\AppData\Local\Temp\flntgz-6762.gz: Permission denied gzip: Error: Error writing compressed file "FFF-Setup-Output.cas.gz" Error: Error writing compressed file Error Object: #f Error: Error writing "| gzip -2cf > FFF-Setup-Output.cas.gz". Error Object: #f I am using Windows 10. Can someone give a solution for this. Thanks in Advance. |
July 15, 2017, 20:35 |
Aureliano Sancho
Rep Power: 13 |
you can to see the environment variables and the path of the Ansys, maybe this is the problem. |
July 16, 2017, 00:41 |
Njit
Rep Power: 9 |
Hi
Thanks for your reply. Can you please elaborate in detail. I could not really understand how to fix that or the problem. |
July 16, 2017, 22:32 |
Lucky
Rep Power: 66 |
There is a known issue with old versions of Fluent (before v17) in Windows 10 where the gunzip utility will not run. The utility that comes with the Fluent installation simply isn't compatible with Win10 and you need to use one that is. You can test it by manually gunzipping any file using the utility in the Fluent directory. If it fails then you've found the culprit.
Error writing compressed file during auto save |
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 04:16 |
making ANSYS fluent automated work, by itself, changing BC and saving data. | Ash Kot | FLUENT | 1 | July 22, 2016 05:21 |
Lift and Drag pattern change wit FLUENT 16 and 13 PISO for same mesh n solver setting | arunraj | FLUENT | 0 | June 2, 2016 22:58 |
Saving point cloud in Fluent | a_soli | FLUENT | 0 | April 14, 2016 11:13 |
Error when saving Fluent cases | Riaan | FLUENT | 0 | August 18, 2006 16:17 |
