Airfoil + Spinning Wheel Problem
Old   July 24, 2017, 10:41
Smile Airfoil + Spinning Wheel Problem
Mik511 is on a distinguished road
Hi!
I'm trying to study the effect of a spinning wheel placed right behind a airfoil. After I ran the study on fluent, i went on to check the velocity stream function and it doesn't make much sense to me mainly because of the velocity direction of the flow on the pressure surface. As you can see, the flow comes from the left to the right but at some point it reverses and it flows trough this surface on the opposite direction.
I'm kind of new to CFD so any help is very welcome on explaining me why is this happening and also why doesnt the flow velocity follow the wheel direction when it's close to it. I uploaded somes images so that you can have a better understanding of the problem.
Useful data:
Flow velocity an inlet: 15 m/s
Ground Velocity: 15 m/s
Wheel Rotational Velocity: 65.6 rad/s (counterclockwise)
Thank you!!
Mik511 is offline   Reply With Quote
airfoil, stream function, wheel
Meshing a Wheel in Pointwise/Fluent problem Marli Pointwise & Gridgen 6 March 27, 2020 00:47
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 12:42
Car external aerodynamic with wheel spinning issue hokhay FloEFD, FloWorks & FloTHERM 2 August 18, 2016 04:23
Problem Meshing Airfoil erodv OpenFOAM 12 January 11, 2012 17:46
solving airfoil like square cylinder problem? zonexo Main CFD Forum 1 May 27, 2006 15:16
