July 26, 2017, 10:50 |
Command line reference ANSYS fluent
Alex
Rep Power: 9 |
Hello.
I have several C mesh boundary with airfoil wall case files that I would like to set up via Fluent to set up the inlet properties (velocity) and the type of viscous model that I would like to use. I have a general reference for what the journal file should look like to send it to a cluster (i believe running on linux): /file/read-case file.cas /solve/initialize/set-defaults/y-velocity 0 /solve/initialize/set-defaults/x-velocity 0 /solve/initialize/set-defaults/z-velocity 0 /solve/initialize/set-defaults/pressure 0 /define/boundary-conditions/velocity-inlet inlet no no yes yes no 25 no 0 no 300 yes /solve/initialize/initialize-flow /parallel/partition/print-active-partitions /define/boundary-conditions/list-zones /solve/set/max-iterations-per-time-step 40 /solve/monitors/residual/convergence-criteria 0.005 0.0001 0.0001 0.0001 0.00001 /solve/set/time-step 0.00020 /solve/set/number-of-time-steps 500000 /solve/set/p-v-coupling 20 /file/auto-save/data-frequency 0 /solve/iterate 50 /solve/update-physical-time /file/auto-save/data-frequency 500 (Do ((x 1 (+ x 1))) ((> x 500)) (Ti-menu-load-string (format #f "/solve/iterate 20")) (Ti-menu-load-string (format #f "/solve/update-physical-time")) ) ;(Do ((x 1 (+ x 1))) ((> x 6000)) ; (Ti-menu-load-string (format #f "/solve/iterate 20")) ; (Ti-menu-load-string (format #f "/solve/update-physical-time")) ; ) close-fluent I tried to repeat this by going through the GUI first and setting everything up and writing a journal file, but the syntax and format of the file looks completely different: (cx-gui-do cx-activate-item "MenuBar*ImportSubMenu*Mesh...") (cx-gui-do cx-activate-item "Question*Cancel") (cx-gui-do cx-activate-item "MenuBar*ImportSubMenu*Mesh...") (cx-gui-do cx-activate-item "Question*OK") (cx-gui-do cx-set-file-dialog-entries "Select File" '( "/home/directory/meshNACA0012.msh") "Mesh Files (*.msh* *.MSH* )") (cx-gui-do cx-set-list-tree-selections "NavigationPane*List_Tree1" (list "Setup|General")) (cx-gui-do cx-set-list-tree-selections "NavigationPane*List_Tree1" (list "Setup|Models")) (cx-gui-do cx-set-list-selections "Models*Table1*List1(Models)" '( 2)) (cx-gui-do cx-activate-item "Models*Table1*List1(Models)") (cx-gui-do cx-activate-item "Models*Table1*PushButton2(Edit)") (cx-gui-do cx-set-toggle-button2 "Viscous Model*Table1*ToggleBox1(Model)*Transition k-kl-omega (3 eqn)" #t) (cx-gui-do cx-activate-item "Viscous Model*Table1*ToggleBox1(Model)*Transition k-kl-omega (3 eqn)") (cx-gui-do cx-activate-item "Viscous Model*PanelButtons*PushButton1(OK)") (cx-gui-do cx-set-list-tree-selections "NavigationPane*List_Tree1" (list "Setup|Materials")) (cx-gui-do cx-set-list-selections "Materials*Table1*List1(Materials)" '( 1)) (cx-gui-do cx-activate-item "Materials*Table1*List1(Materials)") (cx-gui-do cx-activate-item "Materials*Table1*ButtonBox2*PushButton1(Creat e/Edit)") (cx-gui-do cx-activate-item "Create/Edit Materials*PanelButtons*PushButton1(Close)") (cx-gui-do cx-set-list-tree-selections "NavigationPane*List_Tree1" (list "Setup|Cell Zone Conditions")) (cx-gui-do cx-set-list-tree-selections "NavigationPane*List_Tree1" (list "Setup|Boundary Conditions")) (cx-gui-do cx-set-list-selections "Boundary Conditions*Table1*List2(Zone)" '( 1)) (cx-gui-do cx-activate-item "Boundary Conditions*Table1*List2(Zone)") (cx-gui-do cx-activate-item "Boundary Conditions*Table1*Table3*Table4*ButtonBox1*PushBut ton1(Edit)") (cx-gui-do cx-set-list-selections "Velocity Inlet*Frame3*Frame1(Momentum)*Table1*DropDownList6 (Velocity Specification Method)" '( 1)) (cx-gui-do cx-activate-item "Velocity Inlet*Frame3*Frame1(Momentum)*Table1*DropDownList6 (Velocity Specification Method)") (cx-gui-do cx-set-real-entry-list "Velocity Inlet*Frame3*Frame1(Momentum)*Table1*Table16*RealE ntry2(X-Velocity)" '( 1)) (cx-gui-do cx-activate-item "Velocity Inlet*PanelButtons*PushButton1(OK)") And it goes on and on.... I ran the latter and I got an exitcode of 2 from my cluster. Looking online it seems that this is indeed an issue with the shell builtins, which I identify as the format not being correct. This is obvious, as the journal file seems to have been written for a GUI rather than a command prompt. Any help is appreciated. I am using Fluent 17.0 up to 17.2. Essentially I want to find a list of the commands for the linux machine on the cluster. Also, I don't understand what the case file can and cannot cover. On the case file I had the solution initialization as well as the BC ready and all, but from the example I have it seems like everything needs to be done on the command prompt. Any help is appreciated. Last edited by alaspina; July 27, 2017 at 11:52. Reason: Clarifying |
July 27, 2017, 00:12 |
#2 | |
Kushal Puri
Rep Power: 12 |
Writing a journal file from the fluent actually capturing all the movement of the mouse (eg, where u are clicking and what u are selecting etc). But using a command iis the direct way to access the panel. |
July 27, 2017, 11:48 |
Alex
Rep Power: 9 |
cluster computing, fluent, linux |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
problem with turbulence models after compilation? | lfgmarc | OpenFOAM Programming & Development | 19 | November 20, 2013 00:50 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
compile error about FJMPI | chiven | OpenFOAM Installation | 11 | March 31, 2010 06:27 |
