Sumedh Jain
Rep Power: 0 ![]() |
I am running large cases on fluent (case file 10GB) in Fluent on parallel on multiple nodes using infiniband. I always fall into this problem where fluent takes large time while building the mesh. This is problem occurs 7/10 times I run a case but in other instances it runs smoothly.
I usually use read/partition/metis to open my case files, have also enabled parallel/fast i/o option (have tried without that too) Have anyone found a workaround for this issue?? Each node that I use had 20 Intel Xeon processors and 128 GB RAM, I usually use 5 of them! Help is much appreciated |
case file read, fluent, slow read, slow write speed |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
How to setup a simple OpenFOAM cluster? | TommiPLaiho | OpenFOAM Installation | 3 | October 27, 2013 15:15 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
Changing the grid on the same set-up | Katya | FLUENT | 7 | October 8, 2009 16:31 |
