Refprop Error 203 with Compressible Flow Boundary Conditions for an Ejector |
September 20, 2017, 02:58 |
Jeff Yam
Rep Power: 8 |
I am having an Refprop error 203,tprho(density) when i try to use hybrid initialization.
My simulation is as follows for a Ejector 2D axi-symmetric model using k-omega SST. Working Fluid: R134a superheated vapour using real gas properties in NIST a) (Pressure-inlet) Inlet Motive Pressure = 28 Mpa and T = 357.4k b) (Pressure-inlet) Inlet Entrained Pressure = 4Mpa and T = 283k c) (Pressure-outlet) Outlet Pressure = 8.3Mpa and T = 303.5k My guess is that there are problems with the Boundary Conditions. However, i ensured that my B.C. are in the bounded range provided by NIST database. |
September 27, 2017, 12:15 |
Jeff Yam
Rep Power: 8 |
any help guys, i am still stuck with this problem.
January 8, 2018, 05:39 |
Refrop error 203
JINOOP
Rep Power: 8 |
I am also getting the same error for CO2 media.
Kindly help |
January 8, 2018, 19:56 |
Lucky
Rep Power: 66 |
Have you tried standard initialization?
January 9, 2018, 00:23 |
JINOOP
Rep Power: 8 |
Yes, i have tried with standard intialization also.
January 15, 2018, 05:49 |
Difference between std and hybrid intitialization?
Jeff Yam
Rep Power: 8 |
Can i ask what is the fundamental difference between std and hybrid intialization?
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
3-D Compressible Flow Boundary Conditions | Tyler | FLUENT | 4 | February 5, 2009 19:58 |
boundary conditions for compressible flow | George | Main CFD Forum | 12 | March 16, 2005 09:26 |
