How to find pressure drop in an element?
Like Tree1Likes
  • 1 Post By Haidar Fakhri
Old   September 29, 2017, 07:53
Default How to find pressure drop in an element?
Jigs
jmex is on a distinguished road
I am looking to analyse pressure drop across a boundary region having a structure like below
Any idea on how to begin as structure dimension is very small.
Thanks,
jmex is offline   Reply With Quote
Old   October 5, 2017, 07:42
Jigs
Can someone help in this case?
I'm stuck in this situation as the the part is having very tiny hole like gaps for the flame to pass through. This part will stop the flame to pass and hence there will be pressure drop. I would like to simulate the same in either CFX or FLUENT. Any way i could do the same. How to mesh such a tiny hole? I am thinking to draft a single hole and import geometry in ansys for meshing. But will it be perfect way to find pressure drop across the part which is usually placed in a pipe?
Old   October 26, 2017, 06:57
Jigs
Is it possible to define that portion as porosity? If yes, then how can i find value of porosity knowing pressure drop from practical data?
Old   October 29, 2017, 02:46
Haidar Fakhri's Avatar
Suraji
Haidar Fakhri is on a distinguished road
Hi jmex
Use probe in Cfd post. It can help u
Thanks
Haidar
jmex likes this.
Haidar Fakhri is offline   Reply With Quote
Old   October 30, 2017, 05:12
Jigs
Originally Posted by Haidar Fakhri View Post
Hi jmex
Thanks
Haidar
Thank you so much for your reply Haider.
How to define probe which will show porosity value?
Old   October 30, 2017, 05:19
Suraji
The value will shown at u click on ur point. U can setting the variable what u want.
In the probe will shown xyz, u can input on it
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 14:42
Mesh element for velocity and pressure drop prediction sache Main CFD Forum 2 July 27, 2014 11:03
Mass flow rate prediction of Purge control valve using set pressure drop enr_venkat CFX 11 February 27, 2014 11:30
CFX-Pre problem, pls help!!! cth_yao CFX 0 February 17, 2012 00:52
Pressure Drop Calculation mk_mard STAR-CCM+ 3 August 29, 2011 02:06
