How to run perfect gas model for r134a from refprop
Old   October 8, 2017, 21:07
Default How to run perfect gas model for r134a from refprop
Jeff Yam
NozzleNoobie is on a distinguished road
I am trying to run a supersonic ejector simulation using r134a as the working fluid from refprop under the perfect gas model before running it under the real gas model.
I am not able to change the Density to "Ideal Gas" under the "Materials" tab. Attached is the image which shows that i can only choose the real gas option.
May i know how i can change the simulation to run under the perfect gas model?
Update: I figured that i need to run a new material csm file. Does anyone know where i can obtain the relevant properties for r134a? There are 45 properties and i am unsure which material property i need to input.
File Type: png Material Density r134a settings problem.png (26.7 KB, 40 views)
NozzleNoobie is offline   Reply With Quote
Old   October 12, 2017, 02:16
Default Using Refprop in FLUENT
Moritz Kuhn
MKuhn is on a distinguished road
Activating the NIST Real Gas Model in FLUENT
Did you try this way? (Link to designated chapter in user Guide)
Moritz
MKuhn is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
error message cuteapathy CFX 14 March 20, 2012 06:45
Real gas model with UDF Ed FLUENT 4 September 18, 2003 10:42
