Integrating data from UDF to Fluent
Old   October 20, 2017, 13:50
Default Integrating data from UDF to Fluent
say2017 is on a distinguished road
I am currently using a UDF to simulate flow through a heat pipe. The UDF uses an initialization function to set the initial temperature, pressure, and mass flow of the heat pipe. I have been able to compile, hook the functions, and run the simulation with no error messages. However, the source terms (for momentum and mass) and my operating pressure which varies with time do not seem to be directly linked to Fluent. The resulting velocity profile is completely incorrect even though it is being formulated properly in the UDF. There is no difference in the velocity profile when I remove the source terms
How can I ensure that Fluent uses the data from my UDF? Any help with this issue or even a better understanding of how data is passed from the UDF to Fluent would be appreciated.
say2017 is offline   Reply With Quote
udf and programming
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Fluent UDF for thermal NOx larsschwarzer Fluent UDF and Scheme Programming 1 July 18, 2014 08:39
Use of Experimental Data in fluent using UDF anvitaa.sharma FLUENT 2 February 18, 2010 10:46
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 10:16
UDF (write a data file) problem lichun Dong FLUENT 2 July 29, 2005 11:39
