Vacuum System Setup
Old   October 26, 2017, 16:53
Default Vacuum System Setup
boblawblaw is on a distinguished road
Hi everyone,
I am quite new to Fluent and am currently in the design process of a vacuum lifting system. The current issue I am running into is setting up the simulation for the system. I am trying to find the pressure losses associated with this specific geometry where the 6 bottom lines are suction of about 90kPa.
Currently my only design parameter is the pressure as the 6 lines needed to lift a certain weight. I have been trying to model using the inlet conditions as both pressure-inlet and velocity-inlet. I have been setting the outlet condition as outflow since I don't have any requirements yet downline.
I was wondering if anyone has some suggestions on the setup for a problem like this or any information on whether my setup is correct or not. It would be greatly appreciated.
Thanks.
boblawblaw is offline   Reply With Quote
Coupling inlet and outlets massfluxes in an enclosed circulation system NielsB Main CFD Forum 1 October 8, 2015 05:26
Simulation of Controlled Leak into Vacuum System eric.m.tridas OpenFOAM 6 May 6, 2015 09:46
Steady state free surface flow in rotational closed system hilde CFX 5 January 21, 2015 16:47
plz rply urgent regrding vof model for my system garima chaudhary FLUENT 1 July 20, 2007 08:37
Need ideas-fuel discharge system Jan FLUENT 1 October 10, 2006 23:05
