October 30, 2017, 05:13 |
Steady state vs Transcient surface integrals
Vignesh Lakshmanan
Rep Power: 9 |
Hello All,
I am running a case of natural convection inside a domain wherein walls are maintained at -20 deg C and air cools down from 43 deg C to -18 deg C. I run this case both steady state and transcient. I plot The following surface monitor: Integral ---> Wall Fluxes ---> Total Surface heat flux over the walls. I run the transcient simulation until convergence (that is air cools down until -20 deg C). Now at the end of the simulation, the value of surface monitor in both the situations should be same right? If not what is the difference between the steady state and transient surface monitors? Thanks Vignesh |
October 30, 2017, 10:33 |
Lucky
Rep Power: 66 |
There is no difference, the surface monitor does not know what time it is. The surface monitor simply does the calculation based on the current solution (whether this is iteration or time) and outputs it.
If you get a difference result, then it seems your transient simulation converged to a different state than your steady state simulation. It is not the monitor's fault. Something happened differently in the solution. Btw are you running natural convection inside a closed box? You must do this in transient. The steady solver is not meaningful because of issues enforcing continuity. |
October 30, 2017, 23:10 |
#3 | |
Vignesh Lakshmanan
Rep Power: 9 |
Thanks for your reply. Ya I know it is necessary to run transcient. I just wanted to check something. Actually the link to my problem is here, which is where I need inputs: Temperature Pull Down Simulation using Fluent By the way, my steady state and transient surface monitors return the same value With Regards Vignesh |
October 30, 2017, 23:40 |
Lucky
Rep Power: 66 |
That's fine. At least you know, or I hope you are convinced, it's not a problem with the surface monitors.
Steady state simulation with VOF method | Gottkanzler | Fluent Multiphase | 2 | June 14, 2017 08:32 |
MRF steady state mixing time | Swift | FLUENT | 0 | August 11, 2016 05:14 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
