Problem related to defining of species flow rate in FLUENT.
Old   April 8, 2021, 04:48
Default Problem related to defining of species flow rate in FLUENT.
Vinay Chandrakar
chinu007 is on a distinguished road
Hello Everyone,
I am using species transport model for simulating my chemical reaction.
there are two reactants which reacts and forms two products.
Reactant_1+Reactant_2<-->Product_1+Product_2.
From my experimental investigation I have feed flow rate of reactant_1 and reactant_2 in kg/s. and both reactants are going inside the cylinder at the same time.
Geometry is cylindrical with one inlet and outlet.
I have few questions to implement this on FLUENT.
(1) I have one inlet and i can give mass flow rate but I dont know which mass flow rate i have to consider(reactant_1 or reactant_2).
(2) If i am using reactant_1 mass flow rate and will give mass fraction/mole fraction in species panel (for reactant_1 and reactant_2), is it the right way of doing it?
(3) Do I have to provide two different inlets and give feed flow rate of each reactant with mole fraction of each as 1 individually and for other as 0?
chinu007 is offline   Reply With Quote
reacting flows, species transport model
Finding shear rate of flow in fluent prkoirala FLUENT 4 September 7, 2020 03:37
Massflow rate problem for an incompressible flow clecle69 STAR-CCM+ 12 March 1, 2017 14:29
basic fluid flow problem - is there a way to switch pressure to a flow rate in analyt vlnikolic Main CFD Forum 3 September 16, 2016 04:07
DPM total mass flow rate yow FLUENT 0 July 17, 2015 12:01
rotor 37 choking mass flow rate fluent simulation sehs15 FLUENT 1 January 15, 2015 06:07
