Problem of seeing vectors rotating in a plane |
December 1, 2017, 13:57 |
I am simulating a flow which is rotational in a tube with some grooves in it. Its sort of rotationally periodic segment. I want to see velocity vectors in a 2d-plane, that I made in Fluent but it does not show rotational flow in vector plots/ . I mean in the regions of grooves. Where I am doing wrong?
Fluent inputs ======== mas flow inlet x,y and z direction = 0 0 1 (Cartesian X, y and z) Rotation about z axis Flow is rotationally periodic about z axis. |
[ANSYS Meshing] Cut Plane Problem | cfdizzle | ANSYS Meshing & Geometry | 0 | December 4, 2014 15:54 |
Rotating Wall Problem Not Working | dreamchaser | CFX | 4 | September 29, 2014 10:09 |
Rotating Wall Problem for Elastohyrodnamic Lubrication | dreamchaser | Main CFD Forum | 0 | September 25, 2014 14:42 |
Errant Velocity Vectors in Rotating Reference Frame Prop Sim | Muzz | STAR-CCM+ | 1 | August 21, 2014 10:22 |
Problem with VOF and rotating disc in Fluent | Ludvig | FLUENT | 1 | March 13, 2014 19:57 |
