December 8, 2017, 15:55 |
Read Heat Flux at One Point
Rep Power: 8 |
Hello everyone,
So, I am modelling a simple wall, transient thermal analysis using Fluent. As a boundary condition on the interior side, I am imposing a temperature fluctuation and a film coefficient. As a boundary condition on the exterior side, I am imposing a fixed temperature and a film coefficient. The rest of the surfaces are adiabatic. I then create a point on the interior side and on the exterior side. In each point, I want to monitor the temperature and thermal flux. For the temperatures all nice and correct, including the variation on the exterior side. But the problem is the flux. When I monitor the flux on the exterior side is way superior when comparing with my experimental setup. I am doing as follows: Create a point on the exterior side - Report Definitions - New - Surface Report - Vertex Average - Wall Fluxes - Total Surface Heat Flux. Is this the correct way to monitor the flux at a point? or choosing this will lead to superior heat flux values? Thank you very much in advance |
Monitor Heat Flux in CFD-Pre | cltormar | CFX | 5 | November 20, 2014 11:45 |
chtMultiRegionFoam heat flux | sailor79 | OpenFOAM Running, Solving & CFD | 0 | September 27, 2013 08:08 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 22:22 |
