UDF help for heat generation
Old   December 26, 2017, 09:55
Lightbulb UDF help for heat generation
amg
gtamogh is on a distinguished road
Hi i am new to UDF writing
My problem is to increase the temperature of the solid volume (2d) at certain flow time, say around 4 second and should reach with maximum unknown temperature for this flow time.
Once flow time, say 4 second is reached the temperature is been reported at monitor plot and Heat generation should stop
(after this 4 second the cooling water would take out the heat generated in the solid volume)
kinetic equation is
Tfo = Tfi + [Tro − Tfi] (1-exp(-UA/mCp))
Tfi=298k is inlet of cooling fluid
Tfo= in unknown (final water temp)
U is energy, mcp are the rest of the properties
i have tried some c-code but no luck.. kindly help
gtamogh is offline   Reply With Quote
Old   December 27, 2017, 03:58
Alex
EternalEnvy is on a distinguished road
Use RP_Get_Real("flow-time") to get the real flow time. As for the temperature, if you need to set the temperature of the boundary, just write a DEFINE_PROPERTY macro to adapt the temperature to the time.
EternalEnvy is offline   Reply With Quote
Old   December 27, 2017, 20:26
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
take a look into Ansys Customization Manual
find there DEFINE_PROFILE not DEFINE_PROPERTY macros.
about time, it is better to use build-in macros CURRENT_TIME.
time = CURRENT_TIME;
best regards
AlexanderZ is offline   Reply With Quote
Old   January 2, 2018, 08:41
Default Thank u
amg
I will try to write code thanks for the help
heat equation, heat generation rate, kinetic energy
Replicating Scalable Wall Function with a UDF yousefaz FLUENT 0 August 4, 2017 02:30
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 00:53
UDF Generation mitalibasargi Fluent UDF and Scheme Programming 0 February 26, 2014 07:10
udf for heat generation sarah l Fluent UDF and Scheme Programming 1 October 16, 2013 17:48
UDF programming fullmonty FLUENT 5 June 30, 2011 02:40
