Coefficient of Drag of a projectile for different Mach Numbers |
January 12, 2018, 12:09 |
Rep Power: 8 |
Hi guys,
I am in need of some help with a simulation. I am looking to do a simulation to find the coefficient of drag around a 155mm projectile for multiple Mach Numbers. I am approaching this as a 2D simulation. Currently any value I get for CD is blatantly wrong (in the thousands but should obviously be below 1). For low velocities of around 3 m/s the result would appear correct although obviously projectile travel much faster than this. At high velocities the result i get is in the millions so is obviously not correct. ANyone have any ideas that can help me in my problem. I have been following an adapting these two tutorials as i go along in the hope of getting things correct: https://confluence.cornell.edu/displ...+Physics+Setup https://confluence.cornell.edu/displ...+-+Step+4+*New I also hope to get a illustration of the pressure around the projectile that shows how the pressure at the back of the projectile is lower due to the fact it is a blunt body. Thanks. |
January 12, 2018, 15:52 |
Daniel Edebro
Rep Power: 10 |
In order for the Cd to be correct you need to specify the right reference values.
January 12, 2018, 16:50 |
Rep Power: 8 |
January 12, 2018, 17:17 |
Daniel Edebro
Rep Power: 10 |
The "Reference values" in the tree view. Can also be found under the tab "Setting up physics" and "Reference values"
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 05:18 |
Drag Coefficient for Ellipse Form (2D) | Ketut Utama | Main CFD Forum | 8 | December 11, 2014 11:03 |
Strange values in drag coefficient of a fuselage | Victor31 | FLUENT | 5 | May 14, 2014 11:30 |
problem with saving drag coefficient | colopolo | FLUENT | 5 | April 12, 2013 10:59 |
Plot drag coefficient against Y(distance) | edwin | FLUENT | 0 | February 4, 2008 09:41 |
