Is it possible to use Eulerrian-Eulerian with large bubble size |
January 13, 2018, 22:25 |
Tleja
Rep Power: 12 |
Hi everyone
I'm studying hydrodynamic in Bubble column. As i seen in Experiment, bubble size of 1-2 cm was discharged from nozzle. At the moment, i used Eulerian-Eulerian model for simulating bubble behavior with Fixing bubble size of 1cm (Secondary phase). I can't simulate this bubble column. It shows divergence in 20 iterations of first time step. I found some information from ANSYS theory about the relation of mesh size and bubble size. Therefore, I changed bubble size in my simulation from 1 cm to 0.5 mm. The well convergence simulation was found. Experimentally, the flow behaviors of 1cm and 0.5 mm bubble size are completely different. I prefer to use bubble size of 1 cm for this simulation. How can i do with simulating big bubble size in Bubble column? I prefers to use Eulerian-Eulerian model. Should i use Eulerian-Eulerian with Multi-fluid VOF??? Best Regard Tleja |
mesh size in Eulerian multiphase flow - liquid/solid mixture | microfin | FLUENT | 4 | December 23, 2016 13:55 |
Bubble size analysis in Fluidized beds | Musa | FLUENT | 1 | March 18, 2013 04:01 |
Diverging wall scale due to large domain size | Kevin | CFX | 3 | November 12, 2006 15:48 |
Query on VOF for Bubble rise | Vamsi | Main CFD Forum | 0 | December 22, 2005 00:02 |
How large the CFD market size is ? | Dong-Kyu, Chung | Main CFD Forum | 13 | September 29, 1998 23:44 |
