January 15, 2018, 05:42 |
Residuals in transient modeling
Marcin
Rep Power: 9 |
I'm performing analysis of the flow throught some geometrical object, which temperature is rising. After some timesteps, the scaled residuals for the every timestep starts from the level that is considered as converged (10e-3 for the flow and 10e-6 for energy). The temperature is still rising. Is there a necessity of using >1 iteration for timestep in this situation? Regards Destroy |
January 15, 2018, 15:27 |
Lucky
Rep Power: 66 |
Sorry I can't follow what you are trying to say about residuals.
But, at each time-step, you need enough iterations for the temperature at that time to converge. This means that at each time-step, you need to see the residuals drop to your convergence criteria (1e-03 for continuity and 1e-06 for energy) before moving onto the next time-step. You should also monitor the temperature vs iteration at each time-step to see that the temperature has converged. |
Residuals in a Transient valve analysis. | Mames | Main CFD Forum | 0 | June 13, 2016 11:05 |
VOF transient: Should residuals converge at each time step? | jpina | Fluent Multiphase | 1 | April 9, 2016 02:26 |
Large transient ".trn" files when doing time average | dtmith | CFX | 2 | June 28, 2015 09:06 |
Modeling transient negative pressure (suction pressure) in outlet | N_mrtz | FLUENT | 1 | July 18, 2013 20:59 |
Laminar gas flow under slight suction - transient works but not steady | audrey | CFX | 1 | September 8, 2011 19:43 |
