Wall heat flux: Ansys Fluent
Old   January 15, 2018, 05:48
Default Wall heat flux: Ansys Fluent
Shavkat Kholmatov
shavkat is on a distinguished road
Dear All
I am facing an issue with Ansys Fluent. I am solving a (molecular) multi-component gas flow using Low Pressure boundary slip. I have run it with tetrahedral mesh and also polyhedral (tet converted to poly directly in Fluent).
The results look OK except one part: the model with Poly mesh shows a sort a line of high surface heat flux across the Wall. All other results including Temperature and Velocity fields look OK. This surface (wall) heat flux could be a local phenomena. Interestingly, I started this problem first using Tet mesh and no such issue. Only with (converted Poly) I do see this on the contour plot of Wall heat flux
Anybody, any idea where it can come from? And how to resolve this?
shavkat is offline   Reply With Quote
Some questions about flow boiling simulation in Fluent beastieboys6 FLUENT 8 November 20, 2017 23:47
wall heat flux in openfoam hz283 OpenFOAM 1 January 4, 2014 07:51
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Heat transfer BC at wall- why need wall thickness? Julie FLUENT 7 February 3, 2012 21:41
how to impose experimental dat as boundary conditi Rogerio Fernandes Brito FLUENT 14 November 25, 2008 05:47
