January 26, 2018, 05:28 |
Axisymmetric results
Xilef Smith
Rep Power: 9 |
Dear,
I'm running simulations for an axisymmetric vehicle and was wondering if the obtained results are then for the 'entire' vehicle? For instance, does the obtained drag still need to be multiplied by two in order to get the full vehicle drag? And is the pressure distribution only for one side of the vehicle? etc. I suspect these are the values for the whole vehicle but I wanted to be sure. Please advice, cheers! |
January 26, 2018, 05:37 |
Daniel Edebro
Rep Power: 10 |
The results (eg Forces using fluent force calculator) when solving axisymmetric 2D problems is for the whole/3D problem. You can ensure this by for example doing a surface integral on a surface with known area.
January 30, 2018, 06:03 |
Xilef Smith
Rep Power: 9 |
Thanks for your answer!
Save Results automatically by APDL Command | ansyxyz | ANSYS | 1 | June 5, 2018 08:16 |
Results of an axisymmetric simulation in Fluent | ShimiSan | FLUENT | 0 | July 19, 2016 09:20 |
Transient Run - Output "Time" in partial results? | evcelica | CFX | 2 | May 16, 2012 21:36 |
Comparison of axisymmetric case, Starccm+ and OpenFOAM | linnemann | OpenFOAM Running, Solving & CFD | 12 | June 16, 2011 05:43 |
Modeling the flow in a fully axisymmetric case %e2%80%93 results with no peripheral symmetry | evgenia | OpenFOAM Running, Solving & CFD | 0 | February 14, 2008 10:23 |
