February 19, 2018, 04:58 |
How do I get temperature of cell thread
JuBong
Rep Power: 8 |
Hi everyone.
The square module was given a grid of 100 cells of 10 x 10. The left side is the entrance, the right side is the exit, the top and bottom are the walls. The inlet is the velocity-inlet, the outlet is the pressure-outlet, and the top and bottom are the insulation conditions. I want to use the temperature of the center of each cell in the thread of 10 cells on the inlet side to enter the temperature on the inlet side. However, the fluent is turned off. Is my method wrong? Is not C_T (c, t) bringing the temperature of the center of the cell? Or is it because you did not enter the initial conditions? How do I get the temperature of each center of a cell thread? I would really appreciate your reply. This is my code. ----------------------------------------------------------------------- #include "udf.h" DEFINE_PROFILE(temperature, thread, position) { real x[ND_ND]; real y; face_t f; Thread *t; cell_t c; real temp; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y = x[1]; temp = C_T(f,t); F_PROFILE(f, thread, position) = temp + 30; } end_f_loop(f, thread) } ----------------------------------------------------------------------- |
February 22, 2018, 13:00 |
adjacent cell temperature
Adam
Rep Power: 8 |
I am working on heat transfer in the naturally aspirated diesel engine. Currently I use Ansys Fluent to simulate the total cycle of the engine my goal is to correct the estimate of the heat flow.
My problem is that I can not define the domain of computing ie the combustion chamber, precisely how to define in UDF: the temperature (TC) of the cell adjacent to the walls? Please orient me to his |
Temperature anomoly at pressure reference cell | will.logie | OpenFOAM Running, Solving & CFD | 22 | July 16, 2021 23:26 |
How to give the temperature condition by using the temperature of next cell in UDF? | JuBong | Fluent UDF and Scheme Programming | 6 | February 19, 2018 06:09 |
Neighboring cells in tetrahedral mesh | vishwesh | OpenFOAM Programming & Development | 9 | November 10, 2017 07:06 |
thread facet cell in flunt | peter | FLUENT | 2 | September 27, 2005 22:16 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
