VIV simulation using FLUENT
Old   February 20, 2018, 14:11
Smile VIV simulation using FLUENT
Sophocles
Sopho is on a distinguished road
Hello guys,
I am a 4th year engineering student and i'm trying to simulate Vortex Induced Vibration around a cylinder using Fluent, for my diploma thesis. I have read many papers so as to get a good understanding on phenomena and the physics that get involved in, and now i have turned to modelling this phenomenon in Fluent.
Before i begin with the simulations of a moving cylinder, i did some simulations of a stationary cylinder. The domain in these simulations was full of water (only water). The results were good and reasonable according to bibliography.
Now i want to move on to the next step, and my final goal is to simulate viv around cylinder inside a tank with water and air. Thus, i want to perform a simulation using VOF and Open Channel Flow. But i have some questions..
1) Which turbulence model is the best for this phenomenon.
2) How can i model hydrostatic pressure? In the region of air the pressure is atmospheric, since it is an free surface, but as you go deeper in the tank the pressure is increasing and is equal to Patm+ρ*g*h. Maybe i could do this, by using a UDF but i don't know how to write this particular UDF. Is there any other possible way to model hydrostatic pressure. I would appreciate if someone shared a similar udf.
Sopho is offline   Reply With Quote
Old   February 20, 2018, 23:40
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Yes this can be done on Fluent. And it is pretty common simulation people are doing. You can find the UDF for 6 DOF on net or even in Fluent UDF manual.
Far is offline   Reply With Quote
Old   February 20, 2018, 23:44
Far
Sijal
You can also go through many videos on youtube
This was done in fluent
https://www.youtube.com/watch?v=_VLUbhNz6Dk"]https://www.youtube.com/watch?v=_VLUbhNz6Dk"]https://www.youtube.com/watch?v=_VLUbhNz6Dk
Done in CFX:
https://www.youtube.com/watch?v=uZeqHBJuM1o"]https://www.youtube.com/watch?v=uZeqHBJuM1o
And this is done in Fluent using 2 way FSI:
https://www.youtube.com/watch?v=nCmKA0-Tgl8"]https://www.youtube.com/watch?v=nCmKA0-Tgl8
Also consider using the overset mesh...
https://www.youtube.com/watch?v=_Cryhe7L3uw"]https://www.youtube.com/watch?v=_Cryhe7L3uw
Old   February 22, 2018, 08:23
Sophocles
Dear Far
Thanks for your response and for the links you provided me. But I still have some questions
1) during a literature survey I did about the turbulence model, I decided to use the kw SST with curvature correction enabled. Could someone tell me if this a good choice?
2) the case I want to model is the following
Moving water at 2 m/s
Stationary air
The cylinder is placed inside the water phase.
In order to simulate this model I have chosen vof with open channel flow. With open channel flow I can use 2 types of boundaries(pressure inlet and mass flow inlet)
When I use mass flow inlet, messages of reversed flow and limited viscosity appear.When I use pressure inlet I can't make the air to be stationary. If someone could enlight me on this problem I would aprecciated it a lot
3) I also want to calculate vortex shedding angular frequency. I think that the right way to do that is from the cl chart. Do you think this is a good approach?
viv fluent vof udf
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 09:07
Start new Ansys Fluent Simulation automatically Malue Fluent UDF and Scheme Programming 1 October 4, 2017 01:48
Which Multiphase Model Should be selected in Fluent for my below described simulation oberstar Fluent Multiphase 0 September 28, 2017 12:05
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
Simulation on fluent 14 NAD FLUENT 0 September 11, 2013 02:05
