What kind of turbulence modeling is applied for my problem in Fluent? |
February 28, 2018, 14:10 |
Rep Power: 8 |
I'm trying to simulate a flow which is exiting from a nozzle. Just tried to know what kind of turbulence modeling is applied in Fluent for my problem. I found something in this page:
http://jullio.pe.kr/fluent6.1/help/html/ug/node404.htm It looks like Fluent uses several kind of turbulence modeling such as Ensemble-average, Time-average, Favre-average. my setting is this: Density-based unsteady using several turbulence modeling e.g. K-omega and K-omega SST and K-epsilon and RSM What kind of RANS modeling is applied in Fluent for my problem? Ensemble-average, Time-average or Favre-average? Are all of these models called RANS? Regards |
February 28, 2018, 17:08 |
#2 | |
Lucky
Rep Power: 66 |
Your turbulence models are the K-omega and K-omega SST and K-epsilon and RSM.
Favre-average is a density-weighted time-average, which therefore makes it an arithmetic density-weighted time-average. The 'RA' in RANS is Reynolds-average, which is typically what most people refer to as time-average. But this is the same as an arithmetic unity-weighted time-average which is simple case of of a Favre-average. The governing equations whether you do RANS/FANS are equivalent once you express them in the Reynolds or Favre variables. What is different is the interpretation of the basic variables and results. Hence, it is not necessary to say whether K-omega is a RANS/FANS or whether it is a time-average of Favre-average because they're all equivalent as far as the solver (Fluent) is concerned. |
Fluent :- turbulence Model | prince_pahariaa | FLUENT | 9 | May 20, 2016 03:41 |
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling | spaceprop | FLUENT | 5 | September 2, 2014 09:43 |
problem with UDF for (v2-f) turbulence model in fluent | artemiss1984 | Fluent UDF and Scheme Programming | 6 | January 17, 2014 05:50 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
Turbulence modeling for fan/compressor blading | Jonas Larsson | FLUENT | 1 | April 13, 2005 14:08 |
