Aeroacoustic analysis of a 2d square cylinder
Old   March 4, 2018, 06:14
Unhappy Aeroacoustic analysis of a 2d square cylinder
Büşra Eren
busraeren is on a distinguished road
Hello, i am currently studying on a 2d square cylinder in fluent. I am very new to fluent but i was able to generate appropriate geometry and mesh for my case with the help of literature search.
I need to use FW method to obtain sound pressure levels, psd plots and vertices. I dont know where to start or how to construct my case properly.
After generating mesh, to obtain more accurate data, i ran the simulation in steady, then transient. Everything seems normal but i dont know how to jump into aeroacoustic analysis after these steps. I put a point in the geometry where i want to obtain sound pressure levels but i couldnt manage to use aeroacoustics branch in fluent. Please help me.
Thank you all.
busraeren is offline   Reply With Quote
Old   March 17, 2018, 05:48
ishan
ishan_ae is on a distinguished road
See this presentation. This is exactly what you are looking for. I used the same to perform a 2D CAA. The biggest problem is to estimate the Source Correlation Length, which I am yet to figure out what it exactly means. It's an input for FW-H model. I think you have to estimate it based on some experimental data. In the tutorial this length has been mentioned.
http://dl.mr-cfd.com/tutorials/ansys...s-Tut2-FWH.pdf
ishan_ae is offline   Reply With Quote
Old   March 17, 2018, 05:54
Büşra Eren
Thank you !
Flow pass 2D square cylinder using LES-channel 395 question Bashar OpenFOAM 1 January 8, 2021 01:53
Drag coefficient of square cylinder tonka Main CFD Forum 2 April 2, 2014 21:42
Please help me!!!!!!! analysis of a semi salvage rotating cylinder in a fluid adambarfi FLUENT 2 June 14, 2012 01:53
grids for flow over a square cylinder student Main CFD Forum 4 April 21, 2009 06:50
Vortex shedding for square cylinder zonexo Main CFD Forum 8 March 30, 2006 15:11
